Differences between a PA-GE and a GEIP in a Cisco 7507
Jan 16th, 2009
We currently have a PA-GE on a VIP2-50 in a 7507 router. What are going to be the differences between that and a GEIP? Can the GEIP card take 2 PA-GE's? Im wanting to make sure we are deploying these items correctly.
Greg
paolo bevilacqua Fri, 01/16/2009 - 08:20
  • Hall of Fame,
    Founding Member
Hi, depending on the intended use, you might something better to properly switch for dual PA-GE. Look at VIP4 or 6. Don;t need to carry a lot of memory unless lot of prefixes.
gregwoodson Fri, 01/16/2009 - 08:22
I dont currently need a dual GigE. I just want to make sure we are deploying correctly now. The question is- what is the difference between using a PA-GE in a VIP2-50 and a GEIP?
paolo bevilacqua Fri, 01/16/2009 - 08:26
  • Hall of Fame,
    Founding Member
The GEIP is a older generation fixed configuration card and you cannot add or take anything from it.
gregwoodson Fri, 01/16/2009 - 08:28
So what is the best way to make sure we dont have performance issues on this PA-GE? Is a VIP2-50 enough? How much performance differences are there?
Giuseppe Larosa Fri, 01/16/2009 - 08:53
  • Hall of Fame,
    Founding Member
Hello Greg,
we had very bad experience with GEIP+.
Real performance was far lower then declared by Cisco.
I think GEIP+ has a processor equivalent to VIP2/50.
We were able to forward up to 280 Mbps of packets of big size (more then 1000 bytes) bidirectional and just 70 Mbps with frames of size 64.
We were using Vlan subinterfaces and we needed to move services to GSR GE interfaces for the low performance.
I would try the PA-GE over a newer and more powerful VIP like 4/80 or more as suggested by Paolo but I'm afraid that wire rate is impossible in C7500 for its internal architecture:
each Cy bus is 1Gbps and is used by vip linecars.
Hope to help
Giuseppe
gregwoodson Fri, 01/16/2009 - 12:34
Ok- now Im a little confused- Which is going to be the best solution for GigE in a 7507? Is it going to be a PA-GE in a VIP4-80? or something else? We just had our vendor say that the PA-GE wouldnt work in a VIP2-50 OR a VIP4-80.
paolo bevilacqua Fri, 01/16/2009 - 13:16
  • Hall of Fame,
    Founding Member
Hmmm actually I had forgot that no VIP supports the PA-GE. Your only choices are the GEIP and GEIP+ with the performance caveats mentioned by Giuseppe.
Giuseppe Larosa Sat, 01/17/2009 - 02:45
  • Hall of Fame,
    Founding Member
Hello Paolo,
wellcome back in the forums
I remember we used a PA-GE on a VIP linecard and it was a 2/50 for IPv6 testing.
Do you mean this PA is not supported on later VIPs ?
Edit:
I have one PA-GE on a VIP 4/80 and it is in use:
NAME: "Line Card 3", DESCR: "Versatile Interface Processor (VIP4-80)"
PID: VIP4-80 , VID: Hardware Version : 2.03, Board Revision : A0, SN: 24644851
NAME: "Card Slot 3,Bay 0", DESCR: "Dual-wide GigabitEthernet"
PID: PA-GE(DW) , VID: Hardware Version : 0.02, Board Revision : A0, SN: 24002063
Edit2:
It is a GEIP linecard actually with fixed configuration dual wide means that takes both bays.
Hope to help
Giuseppe
paolo bevilacqua Sat, 01/17/2009 - 04:07
  • Hall of Fame,
    Founding Member
Hi Giuseppe, the PA-GE is not supported by any VIP:
http://www.cisco.com/en/US/docs/routers/7500/vip2/installation/guide/2658vip2.html#wp133329
A similar document exists for VIP4.
The way cisco made the dual-width PA work on the GEIP, is by splitting TX and RX on the different bays, thus barely meeting the bandwidth constraints of the VIP-pA bus (a modified PCI).
But all in all, we know that the 7500 is not a gigabit class router.
