CUCMBE 7 with Presence 7
Answered Question
Jan 16th, 2009
  • Silver, 250 points or more
Just a quick question for the experts out there. Is CUCMBE 7 capable of being integrated with Presence 7? I was looking at this compatibility matrix and did not see the answer yet I am hearing that this is possible.
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/7_0/english/compatibility/cupcompatibility7x.html
Correct Answer by htluo about 8 years 4 months ago
Ah... looks like they start supporting LDAP from 7.0
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/cmbe.html#wp1045575
"Beginning with Release 7.0, Unified CMBE supports corporate directory integration"
It was not supported on CUCMBE 6.x.
Overall Rating: 5 (3 ratings)
htluo Fri, 01/16/2009 - 08:46
  • Red, 2250 points or more
Yes, it is compatible.
However, since CUCMBE does not support LDAP integration, you might run into some potential problems.
See details on my blog:
http://htluo.blogspot.com/
mattcalderon Fri, 01/16/2009 - 09:00
Thanks for the link. Bookmarked for future reference!
I am looking through the Admin guide for CUCMBE and it shows LDAP as being a configurable option. Is this incorrect?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/admin/7_0_1/ccmcfg/b02ldsys.html
Also release notes showing LDAP
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/rel_notes/7_0_1/cucmbe-rel_notes-701.html#wp613529
Jaime Valencia Fri, 01/16/2009 - 09:02
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCMBE 7 does support LDAP, it's one of the enhancements made
LDAP Support in Cisco Unified Communications Manager Business Edition
Cisco Unified Communications Manager Administration Guide for Cisco Unified Communications Manager Business Edition, Release 7.0(1)
LDAP System Configuration
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucmbe/admin/7_0_1/ccmcfg/b02ldsys.html
EDIT: you beat me by 2 minutes Matt =)
java
if this helps, please rate
mattcalderon Fri, 01/16/2009 - 09:10
Thanks! This will make this install much easier.
Matt
