H.323 Gateway to Callmanager 4.3 - Signalling works, no audio
Jan 16th, 2009
I'm just trying to get to grips with IPT but I'm having some basic problems.
I've got a 2651XM with FXO and FXS ports. From an analog phone connected to the FXS port I can call numbers on the PSTN, and I can also call from the PSTN to my analog phone via connection plar opx.
I added a callmanager 4.3 server and a bunch of IP phones which can all call each other - so far so good.
However, when I add the gateway to callmanager as a H.323 gateway call signalling is fine (I can change the connection plar opx number to an IP phone and it rings) but I get no audio in either direction.
Any suggestions?
Overall Rating: 5 (2 ratings)
Nicholas Matthews Fri, 01/16/2009 - 09:09
  • Red, 2250 points or more
You may want to try using this command if you have multiple IP addresses on your H323 gateway:
interface-level: h323-gateway voip bind srcaddr 1.1.1.1
You can also check this doc I have recently created, little section on using 'show call active voice brief'.
hth,
nick
Adrian Saavedra Tue, 04/14/2009 - 12:21
  • Gold, 750 points or more
Hi Nick,
Thanks for sharing your excellent docs. 5 pts :)
Best regards,
- Adrián.
