Inbound - Preserving Destination Number - Dial Peer/CallManager
Jan 16th, 2009
We have a range of DIDs and need to present the destination number to the device (FaxPress) in a hunt group. If we use a translation pattern, we suspect the destination digits will not be preserved. We may have the same problem with the use of a hunt group. FaxPress has 8 internal numbers on CallManager, how can we round robin inbound calls with various destination numbers, preserving the destination digits so FaxPress can use them to deliver the inbound fax to the correct e-mail recipient?
drubery Fri, 01/16/2009 - 11:16
Looking into creating CTI Port with a DN for every inbound number, than setting those lines to Call Forward All to the Hunt Pilot, this should preserve the destination/dialed number by the calling party for presentation to FaxPress.
drubery Fri, 01/16/2009 - 11:55
CTI Port, set for same location as VG224, that should keep the codec at G.711?
Any limitation on the number of simultaneous calls the CTI Port can handle?
