Call Forward unregistred problem with QSIG
Jan 16th, 2009
i have a PBX that communicates with a Call Manager 6.1 through a trunk QSIG (ECMA) in MGCP with a PRI E1 interface.
The router is a 2811.
the problem is that if i call from a PBX phone one IP phone unregistred that have a CF UNREGISTRED configured with external number, i hear busy tone.
the same situation with a CFA works.
Erick Bergquist Tue, 01/15/2013 - 04:06
Is the forwarding calling search space set correctly on the call fwd unregistered entry? It is none by default, and set both internal and external.
Ahmed Elnagar Tue, 01/15/2013 - 05:47
It is there and the PBX phone rings, but the call drops after 4 secnonds on recovery on timer expiry for T3014 timer as I dont receive connect ack from the PBX.
however for call forward all,busy, no answer it works very normally.
