RME or CS doesn't learn device type of a 4506-E
Answered Question
Jan 16th, 2009
device type shows up as null in device center. Tried to find an update, but I am not clear what SW I should load.
Correct Answer by Joe Clarke about 8 years 1 month ago
You can go to Common Services > Software Center > Device Update, and download all of the available update packages for Common Services and Resource Manager Essentials. That should give you RME 4506-E support.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 01/16/2009 - 11:50
alukes Fri, 01/16/2009 - 13:56
Thanks that was very easy.
I didn't even notice the device upgrade option and was trying to search the Cisco site for updates.
