01-16-2009 10:11 AM - edited 03-15-2019 03:35 PM
Hello --
I am trying to send 911 calls as number Plan ISDN and Type National; and only 911 calls. So I cannot globally change this setting on the PRI, I would like to keep the 'Cisco CallManager' setting on the PRI, so that when I dial 911, it knows to send my digits as ISDN National. I tried to do this using Route Filters, but that only set my Called Number as ISDN National, the calling number was still unknown.
Is there a way to tell callmanager to set my calling number to a certain type with MGCP? I assume its the equivalent of the isdn map in H323 gateways.
Please let me know.
Ohamien
01-16-2009 10:30 AM
Hi Ohamien,
I know that this TON is populated from the NANP text file buried in CUCM. Based upon your CCM version, it will be configured differently.
-nick
01-16-2009 10:31 AM
Hell Ohamien,
Whats is the calling party TON set as on the PRI? Is that set to Cisco Call Manager as well?
01-16-2009 10:34 AM
Yes, currently everything is set to Cisco CallManager. I am using version 6. Any ideas?
01-16-2009 10:36 AM
