6513 with Sup 720 : Modules support in Slot#1-->6
Answered Question
Jan 16th, 2009
What (10/100/1000 Ethernet modules supports in slots 1-->6 on 6513 with Sup720. Iam aware that WS-X6748-GE-TX is not supported.
Thank you in advance
MS
Correct Answer by Jon Marshall about 8 years 1 week ago
MS
CEF 720 modules are not supported in slots 1 - 6.
CEF 256 modules are supported in slots 1 - 6. So Table 4 and 5 contain modules that are supported in slots 1 - 6.
Edit - have a look at Table 2. It states CEF 256 modules are supported in any slot.
Apologies for the confusion.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 01/16/2009 - 11:05
MS
Slots 9 - 13 on the 6513 chassis provide dual connections to the switch fabric. So generally speaking any 6500 CEF 720 interface modules cannot be placed in slots 1 - 6 as they need dual connections although note there are exceptions such as the WS-X6724-SFP module which only has a single 20Gbps connection to the switch fabric and can therefore go in any slot.
Jon
mvsheik123 Fri, 01/16/2009 - 12:00
Hi Jon,
Thank you for the reply. So apart from WS-X6724-SFP , are there any toehr 10/100/1000 Ethernet modules that can go in 1->6?
Thnak you
MS
mvsheik123 Fri, 01/16/2009 - 13:17
Jon, Thanks again.
I have this link. So...
Table 4. Cisco Express Forwarding 256 10/100 and 10/100/1000 Modules
Per your first reply CEF modules will NOT support (in 1-->6).
Table 5. Classic 10/100 and 10/100/1000 Modules :anything goes in anywhere. is that correct..?
Thank you
MS
Correct Answer
Jon Marshall Fri, 01/16/2009 - 13:22
MS
Jon
