857w need help in configuring radio interface
kayasaman
I've tried many times to get help for my 857W as the NAT keeps crashing on me in fact once per day! Yes it really is that severe as I run servers behind it which need to be accessable by the web.
I think the cause of the problem was that I used SDM Express to bridge the Wireless interface with Vlan1?
I am in the process of regenerating the config only I haven't managed to find any documentation through Google in setting up the wireless interface properly.
I'm guessing that bridging it with VLan1 is not the way to go?
I have attached the config I've got so far, if anyone sees anything wrong with it please let me know as I think I've configured the NAT correctly now but I'm not certain. And also if someone could help me with the wireless config too that would be brilliant.
I am running IOS 12.4(15)T
I would be really greatfull for any ideas!
Hello Kaya,
I knew of a limit of up to 2 vlans in this class of small of routers for this I have suggested to use two vlans.
anyway a L3 object vlan will goes up when at least one physical port associated to it is up/up.
you have configured bridge-group 2
you need to apply bridge-group 2 under vlan1 or you need to configure a radio subinterface that uses dot1q 2 and to apply bridge-group 2 to vlan2
Edit:
please change the following:
interface Dot11Radio0.2
encapsulation dot1Q 1 native
in
encapsulation dot1Q 2 native
the real vlan number is the the dot1q vlan-id not the subinterface index that actually can be arbitrary.
For this reason you have no port in vlan2 and for this reason vlan2 SVI (L3 interface) is not up.
Hope to help
Giuseppe
10 Replies 10
Giuseppe Larosa
according to this configuration guide you can bridge between wireless lan and vlan
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/857sg_bk.pdf
Your current configuration doesn't provide a L3 exit point for wireless users because vlan 1 is shut down.
You can use integrated routing and bridging
int BVI X
ip address 192.168.2.1 255.255.255.0
ip nat inside
int vlan X
no ip address
bridge-group X
iinterface Dot11Radio0.X
encapsulation dot1Q X
bridge-group X
bridge-group X subscriber-loop-control
bridge-group X spanning-disabled
bridge-group X block-unknown-source
no bridge-group X source-learning
no bridge-group X unicast-flooding
access-list 11 permit 192.168.2.0 0.0.0.255
+ ip nat inside source list 11 int dialer0 overload
notice the additional specific bridge commands dor interface radio.
or you can choice not to use at all the wireless and you should be fine.
Hope to help
Giuseppe
Thank you for the reply!
I can see that the config you gave for the wireless is similar to the config I'm using currently which is crashing my NAT as severly as every day.
At the moment I'm using vlan1 but have read that Cisco do not recommend to use it.
I have included my current config which does contain the bridge elements but I don't know if it has gone too far by generating some very confusing and strange ACL's.
The question I have to ask now is, would a misconfigured bridge interface cause NAT issues? Or would the NAT issues be due to something else?
Hello Kaya,
your configuration looks like fine.
My suggestion was actually to use two different vlans one for wired ethernet and one for wireless lan.
the NAT configuration then may need to be changed to reflect but it is possible to have two NAT inside interfaces.
This would separate the two broadcast domains and can help.
bridging works at OSI layer 2, NAT works at OSI layer 3 to 5 (at least).
But it is difficult to say what is the problem without a detailed analysis.
Hope to help
Giuseppe
Many thanks again!
If I changed my config for the wireless to use say Vlan2, on network 192.168.0.1 255.255.255.0 would that still be able to communicate with the 192.168.1.0/24 network on Vlan1? Or would I need to use inter vlan switching for it as I'm not sure how to do this?
The output of show dsl interface is:
ATM0
Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM: 0x03 0x2
Chip Vendor ID: 'STMI' 'GSPN'
Chip Vendor Specific: 0x0000 0x0010
Chip Vendor Country: 0x0F 0xFF
Modem Vendor ID: 'CSCO' 'GSPN'
Modem Vendor Specific: 0x0000 0x1000
Modem Vendor Country: 0xB5 0xFF
Serial Number Near: FCZ111840K1
Serial Number Far:
Modem VersChip ID: C196 (0)
DFE BOM: DFE3.0 Annex A (1)
Chip ID: C196 (0)
Capacity Used: 99% 95%
Noise Margin: 11.0 dB 9.0 dB
Output Power: 20.0 dBm 9.5 dBm
Attenuation: 19.5 dB 7.0 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0xC6
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 45209 (0 spurious)
PHY Access Err: 0
Activations: 11
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: init_3.0.33_nobist.bin
Operation FW: AMR-3.0.033.bin
FW Source: external
FW Version: 3.0.33
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 16689 0 798
Cells: 0 30017316 0 42241457
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 37786 0 0
Header Errors: 0 29496 0 0
Total BER: 0E-0 3435E-7
Leakage Average BER: 0E-0 7918E-10
Interleave Delay: 0 20 0 52
Bitswap: enabled enabled
Bitswap success: 0 0
Bitswap failure: 0 0
LOM Monitoring : Enabled
LOM watch configured for 200 times
LOM appeared continuously for 0 times
DSL: Training log buffer capability is not enabled
The error for crc, header and BER values look pretty high is that normal with a dsl line?
Or should a post bakc with a show tech once the system crashes again?
Hello Kaya,
a router when the command
ip routing is configured does its job: that is at least to route traffic between the different connected subnets.
So there shouldn't be problems but only advantages in using two different subnets
About DSL :
the error rate is given by:
37786 / 30017316 = 1,25 10^-3
is actually high
Hope to help
Giuseppe
Thank you!
So now I will deploy a second Vlan for my wireless interface.
Regarding the error rate, that would be caused by the line wouldn't it perhaps by the DSLAM not being provisioned properly?
Should I go and contact my ISP with this and see if they can aleviate the issue?
I mean as long as it's not my box then I know who to contact. Otherwise if it induced by my config somewhere then I will need to sort that.
Oh my I've just learned that the 857 will only support one wired vlan.
Ontop of trying to configure another one.
I'm sorry to have to ask this but would you be able to assist me?
So far I have added:
no ip address
encryption vlan 2 key 1 size 40bit xxx transmit-key
encryption vlan 2 mode ciphers wep40
interface Dot11Radio0.1
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Vlan2
no ip address
interface BVI2
description Bridge between Vlan20 and Dot11Radio0.1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
access-list 1 permit 192.168.0.0 0.0.0.255
bridge 2 protocol ieee
bridge 2 route ip
althuogh it doesn't seem to be working as vlan2 doesn't come up?
Based on this link:
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html
I have attached what I have got so far which doesn't work?
The radio interface doesn't come up?
I am assuming that it is because I haven't got vlan1 configured in a bridge group to interface dot11radio0.1?
Hello Kaya,
Edit:
in
Hope to help
Giuseppe
Thank you for all your help, Giuseppe!
I really appreciate it. Everything is working fine now, although I think I need to upgrade to a larger router as it seems that I've out grown this one but hopefully when I have the budget for it things will be ok. :))
Best Regards
Kaya
