Summary-address Vs Interarea Route
Jan 17th, 2009
I have a added a static route of /32 pool and redistributing the routes in ospf.
e.g 10.1.1.1/32,10.1.1.2/32 and so on.
After that I afvertise the 10.1.1.0/24 pool in ospf.
On remote end I am getting /32 routes as E2 route and one route as O(10.1.1.0/24). There after advertising the 10.1.1.0/24 with summary-address command. On remote PE I am getting one E2 as /24 route. Now my question is where that /24 route gone which I advertise with the help of network.
regards
shivlu jain
Giuseppe Larosa Sat, 01/17/2009 - 04:38
Hello Shivlu,
how you managed to get an O or O IA for 10.1.1.0/24 before ?
now you should have only the O or O IA 10.1.1.10/24 installed in the routing table.
the O E2 should just be there to block the /32.
Actually, what you see is strange but it can derive from how you did the first advertisement.
the following may apply to your case
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_osp1.html#wp1013010
discard route command
Hope to help
Giuseppe
