IPSec VPN with VPN-DES??
Jan 17th, 2009
I have a cisco pix 515e with an image version 7.2, but it dOesn't have a license to support VPN-3DES-AES so I have configured it for VPN-DES but unable establish a remote-access VPN connections.
The configuration is as pasted below, kindly review and suggest any corrections.
CM
vpn-firewall# sh run
vpn-firewall# sh running-config
: Saved
PIX Version 7.2(4)
hostname atheeb-vpn-firewall
enable password xxx
passwd xxx
names
dns-guard
interface Ethernet0
nameif outside
security-level 0
ip address 212.33.x.y 255.255.255.224
interface Ethernet1
nameif inside
security-level 100
ip address 10.1.104.10 255.255.255.0
ftp mode passive
access-list nonat extended permit ip 10.1.100.0 255.255.255.0 10.1.105.0 255.255.255.0
access-list nonat extended permit ip 10.1.98.0 255.255.255.0 10.1.105.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip local pool test 10.1.105.1-10.1.105.25 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 10.1.104.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 212.33.x.z 1
route inside 10.1.100.0 255.255.255.0 10.1.104.1 1
route inside 10.1.98.0 255.255.255.0 10.1.104.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set atheebset esp-des esp-md5-hmac
crypto dynamic-map dyn1 1 set reverse-route
crypto map mymap 1 ipsec-isakmp dynamic dyn1
crypto map mymap interface outside
crypto isakmp identity hostname
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption des
hash sha
group 2
lifetime 43200
crypto isakmp policy 65535
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 20
vpn-sessiondb max-session-limit 450
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
username user password xxxencrypted
tunnel-group test-vpn type ipsec-ra
tunnel-group test-vpn general-attributes
address-pool test
tunnel-group test-vpn ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
vpn-firewall# exit
Logoff
vpn-firewall# sh version
Cisco PIX Security Appliance Software Version 7.2(4)
Licensed features for this platform:
Maximum Physical Interfaces : 3
Maximum VLANs : 10
Inside Hosts : Unlimited
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Disabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : Unlimited
