01-17-2009 01:05 PM
I have a site to site VPN set up and working, but I don't want it to split tunnel. Which it does right now. I want all traffic including the remote side of the Site to Site VPN to surf via us and our content filter. Here is the far side ACL's which I think is where my problems are. I don't do this enough to know so I figure I would ask.
access-list outside_1_cryptomap extended permit ip 192.168.152.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.152.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.152.0 255.255.255.0 172.16.0.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.152.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.152.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.152.0 255.255.255.0 192.168.101.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.152.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.152.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.152.0 255.255.255.0 172.16.0.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.152.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.152.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.152.0 255.255.255.0 192.168.101.0 255.255.255.0
Dan
Solved! Go to Solution.
01-19-2009 11:58 AM
Yep, config looks good, on a side note, if your main site is an ASA you might need to have a nat rule to bring those sites to the internet something like:
nat (outside) X 192.168.152.0 255.255.255.0
global (outside) X interface
And you need the correct same security traffic definition in place:
same-security-traffic permit intra-interface
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/s1_72.html#wp1289167
01-19-2009 12:33 PM
Excellent! be sure to rate this post.
01-19-2009 09:57 AM
Dan,
Tipically Lan to Lan conections are intended for specific traffic to go through the tunnel, in your case since you need to encrypt all traffic from one side to the other, what you need to do is to change your match address statements to accomplish this.
From your remote side you would do something like:
access-list outside.. permit ip
and your central side should have the mirrored acl to the one above:
access-list outside.. permit ip any
You need to be careful when applying this since all traffic behind this remote peer will then start flowing through the tunnel and if internet has not been confirmed to be working via this method you will bring them down.
01-19-2009 10:28 AM
I have changed the access-list to the following on the remote side.
access-list outside... extended permit ip 192.168.152.0 255.255.255.0 any
then the central side I need to add
(Access-list from central side) this still isn't working unless I added it to the wrong part of the ACL.
access-list 100 extended permit ip 192.168.0.0 255.255.255.0 10.100.101.0 255.255.255.128
access-list 100 extended permit ip 192.168.2.0 255.255.255.0 10.100.101.0 255.255.255.128
access-list 100 extended permit ip 172.16.0.0 255.255.255.0 10.100.101.0 255.255.255.128
access-list 100 extended permit ip 192.168.100.0 255.255.255.0 10.100.101.0 255.255.255.128
access-list 100 extended permit ip 192.168.200.0 255.255.255.0 10.100.101.0 255.255.255.128
access-list 101 extended permit ip any 10.100.101.0 255.255.255.0
access-list 101 extended permit ip any 192.168.152.0 255.255.255.0
The 10.100.101.0 is used for remote access VPN and those do in fact push all traffic thru the tunnel and our filters.
Thanks for your help. Let me know if I missed anything.
Dan
01-19-2009 10:31 AM
Hi Dan,
You also need to use the same kind of setup for your NONAT policy, if this is an ASA/Pix you would need that for your nat (inside) 0 .... acl policy the remote end needs this setup as well. Pretty much you will configure the vpn tunnel normally what will change is the traffic definition, instead of being from specific subnet to specific subnet it will be from specific subnet to any so you need to match all policies accordingly.
01-19-2009 10:57 AM
Sorry I am a bit of a newbie here, well actually don't do this very often and then I forget.
These are ASA's.
So now my ACL's on the remote end look like this, and the NAT 0 looks like the following as well.
access-list outside_1_cryptomap extended permit ip 192.168.152.0 255.255.255.0 any
access-list inside_nat0_outbound extended permit ip 192.168.152.0 255.255.255.0any
nat (inside) 0 access-list inside_nat0_outbound
And the ACL and NAT 0 have these entries.
Access-list 100 extended permit ip any 192.168.152.0 255.255.255.0
Access-list 101 extended permit ip any 192.168.152.0 255.255.255.0
Nat (inside) 0 access-list 101
Thanks Again,
Dan
01-19-2009 11:04 AM
That is ok, you can test by pinging anywhere on the internet from behind of the remote end ASA, and get the show crypto ipsec sa from both ends see if the SA is created
01-19-2009 11:19 AM
I will test this tonight and let a note as to whether it worked or not, but the configs look correct? Atlest from the ACL side.
Thanks, Dan
01-19-2009 11:58 AM
01-19-2009 12:25 PM
Looks like things are working. The ASA that these are are connecting to actually push traffic to our netowrk head end. No web surfing through the connection point. So it isn't coming in and going out the same interface. It comes in one interface then gets sent out the inside interface to a router then to our head end.
Anyway I think things are working. Thanks again for all your help.
Dan
01-19-2009 12:33 PM
