router on a stick with dell 5324
Answered Question
Jan 17th, 2009
i set up inter vlan routing with dell switch.I was able to ping hosts in vlan 10 from a host in vlan 30 but host in vlan 10 can not ping host in vlan 30
Does somebody understand this ? Help.
Here is the attached config.
Correct Answer by glen.grant about 8 years 3 months ago
I would check the dell trunk setup sounds like something is not quite right. The native (untagged) vlan should be 1 by looking at your config , that would have to match on the dell. Also if you are using pc's as ping points make sure all software firewalls are shutoff otherwise they will not respond to ping.
Overall Rating: 5 (1 ratings)
kolawole1 Sun, 01/18/2009 - 02:41
I have pc in vlan 10:
ip address 172.16.0.31/16
Gateway:172.16.0.30
pc in vlan 30
ip address 192.168.50.34/24
Gateway:192.168.50.211
After doing extended ping on the router i was able to ping from 192.168.50.0 network to 172.16.0.0 network but ping is not working from 172.16.0.0 to 192.168.50.0
Correct Answer
glen.grant Sun, 01/18/2009 - 04:51
  • Purple, 4500 points or more
