CME and dial plan
Jan 17th, 2009
I have a question about a dial plan, my customer did receive numbers for the PRI form 027000000 - 027000099 he did want that the user phones have the numbers 10 - 99 (so only two numbers), there are also 2 ATA's for fax, is it possible to assign the whole number 027000001 and 027000002 to the fax, what should i use as translation pattern, because i have 2 digits and 9 digits mixed, can someone help
Nicholas Matthews Sat, 01/17/2009 - 15:51
  • Red, 2250 points or more
Number expansion is probably what you're looking for:
Router(config)#num-exp .. 0270000..
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_n1_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1009135
That's the only command you would need to do to expand your entire dial plan out with 9 digits from 2.
This of course, assumes you assign 2 digit extensions to phones and the FXS ports. You can receive the digits from the PRI in either 2 or 9 digit format with this command.
hth,
nick
