DMZ FTP server
Answered Question
Jan 18th, 2009
I have this configuration:
Host 172.16.1.x/24 > ASA 5510 > Router 2811 > Router 871 > ASA 5505 > Host 172.16.2.x/ 24.
I have add an FTP serve on port 2 of ASA 5510 with the ip address 172.16.0.2/252.
I need to know how tho configure the access on the FTP server.
I have configured ASA5510 and ASA5502 like that but the host 172.16.2.x/24 cannot access to the FTP server.
ASA5510:
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_access_in extended permit icmp host 10.52.72.135 172.16.1.0 255.255.255.0
access-list outside_access_in extended permit ip host 172.16.2.2 172.16.1.0 255.255.255.0
access-list outside_access_in extended permit ip host 172.16.0.6 172.16.1.0 255.255.255.0
access-list outside_access_in extended permit icmp host 172.16.2.0 172.16.1.0 255.255.255.0
access-list outside_access_in extended permit tcp any host 172.16.0.2 eq ftp
access-list outside_access_in extended permit tcp any host 172.16.0.2 eq ftp-data
access-list inside_nat0_outbound extended permit ip 172.16.1.0 255.255.255.0 10.52.72.128 255.255.255.192
extended permit ip 172.16.1.0 255.255.255.0 172.16.2.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 172.16.1.0 255.255.255.0 172.16.0.4 255.255.255.252
access-list inside_nat0_outbound extended permit ip 172.16.0.0 255.255.255.252 172.16.2.0 255.255.255.0
nat-control
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 172.16.1.0 255.255.255.0
static (DMZ,outside) 172.16.2.2 172.16.0.2 netmask 255.255.255.255
access-group outside_access_in in interface outside
ASA 5505:
ftp mode passive
dns server-group DefaultDNS
domain-name default.domain.invalid
access-list outside_access_in extended permit icmp host 172.16.0.5 172.16.2.0 255.255.255.0
access-list outside_access_in extended permit icmp host 172.16.1.2 172.16.2.0 255.255.255.0
access-list outside_access_in extended permit ip host 172.16.1.2 172.16.2.0 255.255.255.0
access-list outside_access_in extended permit ip host 10.52.69.120 172.16.2.0 255.255.255.0
access-list outside_access_in extended permit icmp any any echo
access-list outside_access_in extended permit ip host 172.16.0.2 172.16.2.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 172.16.2.0 255.255.255.0 172.16.0.4 255.255.255.252
access-list inside_nat0_outbound extended permit ip 172.16.2.0 255.255.255.0 172.16.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 172.16.2.0 255.255.255.0 10.52.69.0 255.255.255.128
access-list inside_nat0_outbound extended permit ip 172.16.2.0 255.255.255.0 172.16.0.0 255.255.255.252
nat-control
nat (inside) 1 172.16.2.0 255.255.255.0
Correct Answer by Jithesh K Joy about 8 years 1 month ago
Please try to access the FTP server 172.16.0.2 from 172.16.2.0/24 network after the static NAT in ASA5510 'static (DMZ,outside) 172.16.2.2 172.16.0.2 netmask 55.255.255.255'is removed.
Bcoz this static NAT is coming in the flow unnecessarily
Overall Rating: 5 (1 ratings)
Jithesh K Joy Sun, 01/18/2009 - 22:14
Hi Malliot
Have configured any tunnel between both the site? if yes please post the conf. of that as well
Jithesh
p.maillot Sun, 01/18/2009 - 23:16
Hi jetheshkjoy
I have a tunnel between my router 2811 and 871.
I post my conf in few minute.
But the ASA5510 receive this message when I try to connect on FTP server.
%ASA-3-305005: No translation group found for tcp src outside:172.16.2.2/1106 ds
t DMZ:172.16.0.2/21
t DMZ:172.16.0.2/21
Correct Answer
Jithesh K Joy Mon, 01/19/2009 - 02:13
