Two different SFP tranceiver on the same switches
Jan 18th, 2009
I have 2960 and 3560 switch. The first link between them is using GLC-LH-SM. I want to have second link using GLC-BX-U. Is it possible to use two different SFP transceiver like that? I think it shouldn't be a problem, but need expert's advice.
Thank you.
B
Tom Randstrom Sun, 01/18/2009 - 08:15
B
You can mix different SFPs in the same chassis; just like you can run different port speeds on a switch.
You cannot run these particular SFPs links over the same fibers. You will need a different fiber for the new link.
One note: The single fiber application needs the GLC-BX-U and GLC-BX-D SFPs.
miratir Wed, 02/04/2009 - 11:19
yes, its possible to have two different SFP type on a switch. please check Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix in attached file.
