Nokia, WLC & U-APSD
Jan 18th, 2009
We are using Nokia ESeries phone with the standard built-in SIP client.
It works great but to improve the battery life I'm trying to follow a very specific Cisco paper: Cisco Unified Wireless Network Design Guide for Nokia Eseries Phones ( http://www.cisco.com/en/US/docs/wireless/technology/nokia/design/guide/nokia.html )
The issue is related to the U-APSD status check (as described in Monitoring WLC Voice Statistics section - http://www.cisco.com/en/US/docs/wireless/technology/nokia/design/guide/nokia.html#wp40498 ): my Nokie E65 always shows value -15 that sounds to be wrong as described in the Cisco paper.
Is anyone able to tune the Nokia phone in order to reflect the desired setting?
I tryed to change parameters with Nokia Configuration Tool 3.0 without any luck.
Any clue?
Luca
etmarcof Wed, 04/29/2009 - 14:17
Hi Luca,
Have you manage to do that change? Because i would like to do the same.
Best Regards,
Mc
etmarcof Fri, 05/01/2009 - 11:58
Hi Luca,
What security mecanism are you using for wireless?
I have tried to configure EAP-LEAP CCKM without success. Have you manage to do that?
MC
