01-18-2009 07:54 AM - edited 03-04-2019 12:53 AM
01-19-2009 06:45 AM
I think you should be using the ABR of the transit area to connect to the ABR that is apart of area 0. That is R3 should have a virtual link to R2.
01-18-2009 07:56 AM
I'm newbie with OSPF and routing, can you explain, what I doing wrong, that I cann't see
anything OSPF routes from R5?
Here is link that I used
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00801ec9ee.shtml
R3:
router ospf 32
router-id 3.3.3.3
log-adjacency-changes
redistribute connected
network 10.1.3.0 0.0.0.255 area 23
network 10.1.23.0 0.0.0.255 area 23
network 10.1.35.0 0.0.0.255 area 35
network 10.10.10.0 0.0.0.255 area 23
01-18-2009 09:06 AM
A router can't be an OSPF ABR without the presence of area 0.
To correct your situation, you can assign the loopback in R3 in area 0 or create a virtual link between R3 and R2.
HTH,
__
Edison.
01-18-2009 12:19 PM
But I have ABR router R2 that is configured to backbone 0.
Maybe I didn't understand some thing right?
DId I configured network equal to this link
01-18-2009 01:45 PM
By definition, an ABR is a routing participating in multiple OSPF areas.
R3 is participating in multiple OSPF areas but it's lacking area 0.
Until Area 0 is configured locally in R3, the router won't be able to route between areas.
Without changing much your current network topology, the easiest way is to assign loopback0 to area 0.
The link you've presented has the middle router participating on a single non-backbone area - it isn't an ABR and that's allowed.
Your design, the middle router (R3) is participating in multiple non-backbone areas. If you want your design to be similar as the link, you need to make R3 member of area 23 or area 35 in all its links and change either R2 or R5 accordingly.
HTH,
__
Edison.
Please rate helpful posts
01-18-2009 11:09 PM
But what about this link, is it right in configuration?
Here Router R2 doesn't have neighbors on area 0 too.
01-19-2009 06:45 AM
01-19-2009 06:53 AM
You have opened my eyes )
01-19-2009 08:03 AM
I guess you didn't read my first reply...
01-19-2009 08:16 AM
Mr. Ortiz, I guess he missed it because I did not even notice it or else I would have pointed him to it, :-)
