Automatic PAC provisioning failing
Jan 18th, 2009
Good morning guys
I have a 1121 AP and manual PAC provisioning passed but automatic does not. What debug statements can I use to troubleshoot this? I'm also using local RADIUS on the AP and CSSC which I believe does not support manual PAC file import
Attached is the AP config
Thank you All!
carenas123 Sat, 01/24/2009 - 11:02
Make sure that by default, when you use EAP-MSCHAP inner methods, ACS allows authentication attempts up to the specified value you configured on the Service page inside the TLS tunnel if the initial authentication attempt fails. After the fourth failed authentication attempt inside the SSL tunnel, ACS terminates the EAP conversation, resulting in a RADIUS access-reject.
ACS supports issuing an out-of-band PAC file that allows you to generate a PAC that can be downloaded to ACS.
Trending Topics - Security & Network
