Configuration Assistant a SDM Replacement?
smalkeric Fri, 01/23/2009 - 14:32
Cisco Configuration Assistant simplifies the task of configuring, deploying, and administering Cisco small business network solutions.
Making sure the network is configured and operating properly is a complex, costly, and time-consuming task. For those of you who don't want to use Cisco Network Assistant for centralized management, but looking for an easy way of configuration of Cisco devices, there may be an option. If you have got an ISR series router, you will definitely have available also a tool called Cisco Security Device Manager or SDM.
SDM is a Java based configuration and monitoring tool which is usually stored in the device's flash, and it's accessible through a web interface of a device. Just enable a web server on your router (Router(config)# ip http server) and put your web browser to the address of your router.
For more information about CCA click this link.
