Cat 6500 with FWSM
Jan 18th, 2009
Hello All,
Kindly I need your help in this problem, we have 2 CAT6500 with sup720 and FWSM in each.
Problem started when network is down , a lot of loss in the ping to the core switcehs ( from the Direct Edge switches), no clear reason , problem fixed by resetting the FWSM on both switches, note that the FWSM is not configured yet .
Have you met any problem or BUG like that before , do you know any BUG ID?
Thanks & BR
rodrigofreitas Wed, 01/21/2009 - 02:53
Hi, Moamen
I am with a like problem.
We have 1 CAT6509 and 6513 with sup720 and FWSM in each.
At 8:00 o'clok all the network working, but at midday I can ping some networks.
For example: I have 5 Vlans, I can ping Vlan 1, 2 and 3.
When I do the failover the network come back to working and I can ping everything Vlan's.
Can you understand me?
Thanks.
