hello time and hold time in hsrp
Answered Question
Jan 18th, 2009
  • Bronze, 100 points or more
hi every body!
My cisco press book says hold time in hsrp is 3 times the hello time.
I am just wondering if it is possible to set hold time as 50 seconds while keeping the hello time 3 seconds.
thanks a lot!
Correct Answer by Edison Ortiz about 8 years 3 months ago
It will use 3 and 10 - timers from the active router. I did a packet trace and confirmed this behavior.
The configured entry indicates the configuration is different than the current active HSRP router but this value could be the prevailing value if this router was to ever become an active HSRP router.
HTH,
__
Edison.
Here we can see "Next hello sent in 00:00:00.480"
By the way what does 480 indicates?
00.480 indicates milliseconds.
Here we can see the active router does not overwrite the timer on standby-router which contradicts the statement from the link.
Am i correct?
Something is wrong with your setup there. I see the Hot Standby value different on both routers.
Anyway, here is my test:
R2#sh stand
FastEthernet0/0 - Group 0
State is Active
2 state changes, last state change 00:04:08
Virtual IP address is 192.168.12.254
Active virtual MAC address is 0000.0c07.ac00
Local virtual MAC address is 0000.0c07.ac00 (v1 default)
Hello time 3 sec, hold time 10 sec
Next hello sent in 1.592 secs
Preemption enabled
Active router is local
Standby router is 192.168.12.1, priority 100 (expires in 9.396 sec)
Priority 200 (configured 200)
IP redundancy name is "hsrp-Fa0/0-0" (default)
R1#sh stand
State is Standby
1 state change, last state change 00:03:56
Next hello sent in 1.848 secs
Preemption enabled
Active router is 192.168.12.2, priority 200 (expires in 8.072 sec)
Standby router is local
Priority 100 (default 100)
R2#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R2(config)#int f0/0
R2(config-if)#standby timers 20 60
R2(config-if)#do show stand
State is Active
2 state changes, last state change 00:04:49
Hello time 20 sec, hold time 60 sec
Next hello sent in 19.040 secs
Preemption enabled
Standby router is 192.168.12.1, priority 100 (expires in 59.848 sec)
R1#show stand
State is Standby
1 state change, last state change 00:04:39
Next hello sent in 2.168 secs
Preemption enabled
Active router is 192.168.12.2, priority 200 (expires in 41.380 sec)
R1#show run int f0/0
Building configuration...
Current configuration : 178 bytes
interface FastEthernet0/0
description R2
ip address 192.168.12.1 255.255.255.0
duplex auto
speed auto
standby ip 192.168.12.254
standby preempt
no clns route-cache
end
You can see no standby timers command on R1, yet it's using the Active HSRP timers…
HTH,
__
Edison.
Correct Answer by crow930us about 8 years 3 months ago
Ask yourself what kind of traffic is going across your network. If you are using VOIP, how much of an affect would it be if your network was down for 50 seconds, or even 10 seconds.
You need to think about what will be happening to your packets while your Active device is down and there is nothing else routing packets (black hole). Network Admins set up HSRP to provide a first-hop redundancy within a network.
If anything you would want to lower the hello timer down to 1 second and the hold timer to 4 seconds for faster failover.
Correct Answer by Joseph W. Doherty about 8 years 3 months ago
You could, but the reason for hold time being 3x hello time, it assumes 3 lost hellos really indicates a lost neighbor, not just a lost hello packet or two. Holding for 50 seconds would mean there were about 16 missed hellos which really probably doesn't increase the accuracy of the neighbor being down but certainly increases the wait before the HSRP shifts the IP address. If a 50 second hold time was acceptable, you could set the hello time to 16 seconds which would decrease the workload for processing HSRP. (Today, we're usually more interested in even faster reaction to failure, which is why millisecond HSRP [ver. 2] and BFD are supported on newer equipment.)
Hi Sarah :)
You can change the hello and hold timers value with the standby timers command: http://www.cisco.com/en/US/docs/ios/ha/command/reference/ha_s3.html#wp1044847
However, a hold time that high can create convergence issues in your configuration.
A router will wait that long before considering a neighbor unreachable.
HTH,
__
Edison.
Overall Rating: 5 (5 ratings)
Correct Answer
Edison Ortiz Sun, 01/18/2009 - 14:17
  • Hall of Fame,
    Founding Member
Hi Sarah :)
HTH,
__
Edison.
sarahr202 Mon, 01/19/2009 - 22:31
Hi Edison !
Let me quote from the link, you forwarded:
"The timers configured on the active router always override any other timer settings"
I performed a simple lab on two routers( 2500 that is all I can afford now:-), D4 and C3 both are connected via layer 2 switch. D4 is active while C3 is stand-by.
I changed the timers, hello time and hold time to 20 and 60 seconds respectively.
C3##show standby
Ethernet0 - Group 1
Local state is Standby, priority 100
Hellotime 3 holdtime 10 configured hellotime 20 sec holdtime 60 sec
Hot standby IP address is 150.150.150.150 configured
Active router is 196.196.196.4 expires in 00:00:08
The active router has default settings.
D4#show standby
Ethernet0 - Group 1
Local state is Active, priority 200, may preempt
Next hello sent in 00:00:01
Hot standby IP address is 196.196.196.6 configured
Standby router is 196.196.196.3 expires in 00:00:07
Am i correct?
thanks a lot!
Correct Answer
Edison Ortiz Tue, 01/20/2009 - 06:33
  • Hall of Fame,
    Founding Member
Am i correct?
R2#sh stand
State is Active
Preemption enabled
R1#sh stand
State is Standby
Preemption enabled
R2#conf t
R2(config)#int f0/0
State is Active
Preemption enabled
R1#show stand
State is Standby
Preemption enabled
description R2
duplex auto
speed auto
standby preempt
no clns route-cache
end
HTH,
__
Edison.
sarahr202 Tue, 01/20/2009 - 10:31
Thanks a lot Edison!
sarahr202 Wed, 01/21/2009 - 01:31
Hi Edison !
Sorry for being stubborn.
I came up with different scenario.
In your case, you changed the timer on active router. In mine i changed the timer on standby router.
D4e0-------------------sw------------e0C3
where D4 is active while C3 is standby
Here I changed the timer on C3( standby router)
C3(config)#int e0
C3(config-if)#standby 1 timer 20 60
C3(config-if)#end
show standby on C3
show standby
Ethernet0 - Group 1
Next hello sent in 00:00:02.488
Hot standby IP address is 196.196.196.15 configured
Active router is 196.196.196.4 expires in 00:00:09
"configured hellotime 20 sec holdtime 60 sec" ,
Which timers c3 is using, the ones i configured 20 and 60 0r 3 and 10( from the active router)
Thanks a lot!
Correct Answer
Edison Ortiz Wed, 01/21/2009 - 05:58
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
Correct Answer
Joseph W. Doherty Sun, 01/18/2009 - 15:45
Correct Answer
crow930us Sun, 01/18/2009 - 17:41
