missing pseudowire-class in 1801
Jan 18th, 2009
Hi all,
I'm trying to configure client-initiated l2tp on my 1801 box, but I don't have pseudowire-class on the general config help menu...
Does anyone know why I don't have pseudowire-class in my global config?
[Cisco 1801/IOS 12.4(15)T7]
[image c180x-broadband-mz.124-15.T7.bin]
Thank you
LAJoe
Overall Rating: 4 (1 ratings)
Edison Ortiz Sun, 01/18/2009 - 16:09
  • Hall of Fame,
    Founding Member
LAJoe,
You need Advanced IP Services, Advanced Enterprise Services, SP services or Enterprise Services feature set.
The IP broadband feature set is too basic for this service.
HTH,
__
Edison.
Edison Ortiz Mon, 01/19/2009 - 08:25
  • Hall of Fame,
    Founding Member
LAJoe,
Thanks for posting the intended feature and you are right. I was looking under another feature and it provided the information I posted.
I will be curious if you were to upgrade to the recommended feature set and the command is available.
I don't have a 1800 router around so I can't test for you.
__
Edison.
lajoe.aal Mon, 01/19/2009 - 14:03
I am trying to get the upgrade pack for my 1801 (FL1801-BB-AISK9= Cisco 1801 IP Broadband to Advanced IP Services Upgrade), so I should have the answer in a couple of days.
I will post here if this solves my problem.
Thank you again
LAJoe
