about BAR versions
Answered Question
Jan 18th, 2009
just regarding to BAR
If I m using BAR 4.0.11 to do all the backup.... do I have to use the same version to restore the backup as well? can it be using some other version for the retore?
kind regards
Rachel
Correct Answer by rob.huffman about 8 years 16 hours ago
Hi Rachel,
The "best practice" recommendation would be to use the same version for the restore as was used for the backup :) The differences between BARS versions could cause mis-match type errors.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bars/4_0_11/overvw.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
