"diagnostic monitor" command
Jan 19th, 2009
We had an issue with one of our core 7606 routers. Bug ID: CSCsl50569
To prevent issue from occuring in 12.2(33)SRB2, diagnostics can be disabled on the SIP-400 with the following command:
Router(config)#no diagnostic monitor module
I would like to know the impact of this command. Since this is a pretty important router, we would refrain from executing this command unless and until the after effects is totally known. Thanks in advance.
s-doyle Sat, 01/24/2009 - 12:04
Did you ever find out the answer to this?
