ACS and IBM TSCM problem
Jan 19th, 2009
Hi All,
I use ACS 4.1 server and IBM TSCM 5.1 server with FP 24 (for server and client) and CTA client and CSSC client.
At many stations (daily for other stations) is the following problem:
"No matched required credential types in any posture validation rule", temporarily I solve the problem by restarting the SCM service on workstation or restarting workstation.
The first rule of this internal posture is performed on the following IBM Corporation pair: IBM_Corporation:SCM:Violation_count
Logs on the ACS "Failed Attempts active" indicates the following:
- Message-Type: Authen failed
- Authen-Failure-Code: Posture Validation Failure (general)
- EAP Type Name: EAP-FAST
- Reason: No matched required credential types in any posture validation rule
- Cisco:PA:PA-Name: ..
- Cisco:PA:PA-Version: ..
- Cisco:PA:OS-Type: ..
- Cisco:Host:ServicePacks: ..
- IBM_Corporation:SCM:Violation_count: ..
After this messages I verify logs for the same workstation on the ACS "Passed Attempts active" indicates the following:
- System-Posture-Token: Unknown
- Cisco:PA:OS-Type: Windows XP Professional
- Cisco:Host:ServicePacks: Service Pack 2
and workstation is placed into the quarantine vlan.
We used authentication with ACS without credential type IBM_Corporation: SCM in "Posture Validation" and I have no errors and workstation is placed in Healthy Vlan.
I think the problem is with the TSCM, does anyone have any idea how to solve it?
ibmnac6.inf
[main]
PluginName=ibmnac6.dll
VendorID=2
VendorIDName=IBM Corporation
AppList=scm
[scm]
AppType=50
AppTypeName=SCM
AttributeList=attr1,attr2
attr1=20,string,Policy Version
attr2=21,integer32,Violation Count
I use the following ADF file:
[attr#0]
vendor-id=2
vendor-name=IBM_Corporation
application-id=50
application-name=SCM
attribute-id=00020
attribute-name=Policy Version
attribute-profile=in out
attribute-type=string
[attr#1]
vendor-id=2
application-id=50
attribute-id=00021
attribute-name=Violation count
attribute-type=unsigned integer
[attr#2]
vendor-id=2
application-id=50
attribute-id=00010
attribute-name=Action
attribute-profile=out
attribute-type=String
Thanks in advance for your attention.
Best Regards,
Mugur
