ACS AAA
Jan 19th, 2009
Hi ,
I have following problem regarding ACS,If yes how to configure it.
Does ACS Internal database can be used for Domain authentication.
Does domain database can be used for n/w devices authentication through ACS.
darpotter Mon, 01/19/2009 - 07:11
Yes the internal database can be used for domain authentication, but you'd need to enter the usernames with the domain, eg DOM1/Fred
You can do circular proxy with domain stripping... but you wouldnt want to go there.
..or you use the ACS external authentication database feature to re-direct authentications to AD.
