XENPAK-10G-LR does not switch off the laser
Jan 19th, 2009
Hi.
We have a problem with the XENPAK-10G-LR that doesn't switch off the lasser in shutdown state, installed in 6509 with WS-X6704-10GE. The other side of the connection doesn't detects the shut.
I have checked that the X2-10G-LR disables the light, then the other side see the interface as down/down.
What is the cause?
Any method for disable the laser?
Regards.
Jose
kbrinker Tue, 11/03/2009 - 11:58
Jose,
We have a LR Xenpak that does the same thing. What was done to fix your problem?
Karl
Tom Randstrom Tue, 11/03/2009 - 19:42
What IOS release are you running?
Have you checked the release notes to see if this issue has been identified?
jyubero Wed, 11/04/2009 - 03:45
Hi.
We have had the same problem in 7600 (12.2SR) and 6500 (12.2SX).
I checked the realase notes and field notices, without results.
As a workaround, you can activate 'ethernet oam' to check that link is really up (if the other box supports it).
Regards.
Jose
Tom Randstrom Wed, 11/04/2009 - 06:10
I guess you will have to report it as a bug so that it can be fixed in a future release.
