Timestamps for logging
Jan 19th, 2009
i have enabled logging & configured clock time zone and set clock maually in pix525 firewall, but when i issue sh logging command logs are not showing the timestamps.
please find the commands in my firewall:
logging on
logging timestamp
logging buffered notifications
logging trap warnings
logging facility 4
One more thing is after restarting the Firewall clock settings are getting reset.same thing is happening for switches & Router also, but logs are showing timestamp in router & switch.
can anybody help me.
Overall Rating: 5 (1 ratings)
psureshrao Tue, 01/20/2009 - 06:49
can anybody help me on this?
after restarting the router & switch time settings are getting changed.
I am using this command in router & switch
service timestamp datetime localtime.
But in case of firewall timestamp is not showing at all. and after restarting the firewall clock timezone IST 5 30 getting removed.
Danilo Dy Tue, 01/20/2009 - 07:59
  • Blue, 1500 points or more
Router, Firewall, and Switch doesn't have a CMOS battery (like the one in your PC) to keep the time running in the event that the device is restarted or power down. To keep the time, you need an NTP server for your network equipment to sync their time.
