Receptionist experiences audio delay before she can hear the customer
Jan 19th, 2009
The setup is an 1861 with 5 IP phones. I am running version 12.4(22)T The receptionist is saying that when some calls come in from outside customers, she intermittently has a delay of 10 seconds before she can hear the caller's voice. What would cause this to happen? The config of the 1861 is attached. Thanks
Nicholas Matthews Mon, 01/19/2009 - 07:42
What's the call flow?
Something like:
troymaki Mon, 01/19/2009 - 07:57
It should be like this:
The Call Manager is located in my office. It is version
Nicholas Matthews Mon, 01/19/2009 - 08:08
On CUCM, you can try two things:
On the H323 gateway:
Check MTP required
Enable Outbound Fast Start
Enable Inbound Fast Start
Sometimes we see long delays with H323 is required to do slow start.
Otherwise, it would require getting mgcp/pri debugs from the far end gateway, CCM traces, and H323/ccapi debugs from the 1861 - which is messy.
