VPN RA IPSec transform set
Jan 19th, 2009
I've managed to establish a VPN-RA connections using aes-128 sha.
This is the running config:
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto dynamic-map VPN_RA 20 set pfs
crypto dynamic-map VPN_RA 20 set transform-set ESP-AES-128-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic VPN_RA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 20
authentication pre-share
encryption aes
hash sha
group 2
lifetime 86400
I tried then to use aes-192, however i keep getting " %ASA-5-713904: All IPSec SA proposals found unacceptable!" and the connection is dropped
Some doubt then arises: do i have to employ necessarely aes-192 for both PHASE 1 and PHASE 2?
There is something else do i have to change? (DH Group 5?)
Ivan Martinon Mon, 01/19/2009 - 09:48
Phase 1 and 2 do not need to have the same configuration, you can use AES 256 if you want on phase 1 and aes 128 on phase 2. DH 5 is documented to work with RA setup however I have never seen this setup working so my advise is to always use DH2.
Carlo Zaina Tue, 01/20/2009 - 03:13
Perfect, this is clear.
However, how it comes then that if i change the transform set, the negotiation ends with a "all proposals are unacceptable" ?
Ivan Martinon Tue, 01/20/2009 - 07:54
I believe it has to do with the client version, some vpn clients (older ones) did not support higher encryption.
