Need Script Help w/String Compare
Jan 19th, 2009
I am a basic script writer and have not needed to use Java. I now have a need to find strings that are six characters (digits) long and begin with a "1". Using if VAR == "1....." doesn't work. Does anyone have a simple solution for this simple string compare? Do I need to use Java? Example please?
ronupcdef Mon, 01/19/2009 - 10:17
Found it! String methods under the If Step:
If String.StartsWith("1")
Jonathan Schulenberg Mon, 01/19/2009 - 17:48
  • Cisco Designated VIP,
    2017 IP Telephony
Yep.
You can check length with the .Length(6) value.
((variable.StartsWith("1")) && (variable.Length(6)))
