01-19-2009 09:06 AM - edited 02-21-2020 03:13 AM
Hi All,
What are the real advantages of having remote users connecting to the central office using the AnyConnect Client instead of the regular IPSec VPN Client?
I can't seem to find any good documentation about it.
Thank you!
Solved! Go to Solution.
01-19-2009 12:31 PM
The main advantages I see in my experience are:
- There is no need to install a heavy client ~10MB installer file
- I believe it can coexist with other VPN Client vendors
- Less overhead than the cisco vpn client
I am sure you can see many other advantages of the AnyConnect Client in the release notes:
01-19-2009 12:31 PM
