Rob Huffman Mon, 01/19/2009 - 10:07
Hi CCSI,
This is now under RTMT in UC 7.x;
Cisco Unified Real-Time Monitoring Tool Administration Guide, Release 7.0(1)
Connection Port Monitor
Using the Port Monitor
This section describes how to use the Port Monitor for Cisco Unity Connection.
Procedure
Step 1 In RTMT, in the Unity Connection menu, click Port Monitor.
The Port Monitor tab displays.
Step 2 In the Polling Rate field, accept the default or enter the number of seconds between updates in the data on the Port Monitor tab; then, click Set Polling Rate.
Note Setting a low polling rate may impact system performance.
Step 3 Click Start Polling.
The Port Monitor tab displays the status of all voice messaging ports on Cisco Unity Connection.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_0_1/rtmt_master/rtprtmn.html
Hope this helps!
Rob
EDIT: Hey Java, the feelings are mutual my friend!
