voiceMail Problem for external Incoming calls.
Jan 19th, 2009
Unity 5.0(1) and Callmanager 6.1(1)
I have set this up several times before without any problem, but this time I have a problem and I can not find what I have done wrong.
internal calls are correctly forwarded to voicemail accounts on Busy and NA. External incoming calls are also correctly forwarded to the Voicemail pilot number, but instead of Greeting I hear "fast busy". In the Unity Call Viewer I see that the 10 digit number from external caller is forwarded to Unity and the forwarder is the called number, so why I hear this "fast busy"? and not the greeting?
Any hints on where to look further would be appreciated.
rdianat
Bradford Magnani Mon, 01/19/2009 - 11:24
  • Cisco Employee,
Rdianat,
Any errors in the application log for TSP? I would recommend setting the following MAcro traces on Unity:
Call Flow
Call Control
Conversation State
You'll want to gather AvCsMgr and svchost components.
Have you tested thoroughly enough to determine that its 100% ALL external calls and not calls that may just be hitting specific voice mail ports?
Brad
rdianat Mon, 01/19/2009 - 14:14
Hi Brad,
There is no errors in the application logs. I am attaching
Call Flow
Call Control
Conversation State
during a call from 7039398300 to 7035608100. Call is being forwarded to 7777 which is the voice mail.
Could you find something abnormal in these logs?
rdianat
Bradford Magnani Mon, 01/19/2009 - 16:01
  • Cisco Employee,
Took a look at the traces and I'm seeing what looks to be Unity dropping the call.
16:29:45:151,AvDiagnostics_MC,162,2996,-1,,SkinnyTSP,12,[Thread 0x00000BB4] [Device 6] Receive StationStartToneMessage (20 bytes) tone=37=DtReorderTone lineInstance=1 callReference=30017050
16:29:45:150,AvDiagnostics_MC,162,2996,-1,,SkinnyTSP,12,[Thread 0x00000BB4] [Device 6] Processing StationStartToneMessage
16:29:45:151,AvDiagnostics_MC,162,2996,-1,,SkinnyTSP,11,[Thread 0x00000BB4] [Device 6] CAvSkinnyCallStatus::AdvanceCurrentState - Old CallState= New CallState=
Are you sure there are no warnings or errors in the application log at all when this happens? Check to see if any ports are locked. Have you tried rebooting Unity? What still confuses me is that you say its only external calls, which would lead to more of what Jaime mentioned with codec.
I suppose next steps would be to also turn up detailed CUCM traces and pull those and see if someone can look deeper into those for more information on the call.
Brad
Tray Stoutmeyer Mon, 01/19/2009 - 11:28
  • Cisco Employee,
Usually fast busy comes from CUCM but you say you see the call hit Unity so it gets routed to Unity in that case. If that is true, then there should be something in the application log stating an error of some sort. When you call from outside and cause the failure, do you see an error in the application log? If so, please provide it here.
Thanks!
Tray
Jaime Valencia Mon, 01/19/2009 - 12:03
  • Cisco Employee,
  • Hall of Fame,
    2011
have you checked codec?? what kind of GW??
H323? MGCP?
what codec you installed on unity??
if H323 did you configure G711?? otherwise you'll use G729 which is the default
java
if this helps, please rate
rdianat Mon, 01/19/2009 - 14:17
Hi Java,
it is H323. I always use G711 everywhere as I usually have enough BW even for remote sites. However I can check my config again if you could tell me how to see in Unity what codec is configured.
rdianat
safety2008 Tue, 01/20/2009 - 04:25
Rd,
just an fyi. had the same problem here, same release. had to restart server to fix.
rdianat Tue, 01/20/2009 - 08:09
I restarted Unity. No luck yet.
rdianat
