POE on cat6 cable.How much maximum length possible?
Answered Question
Jan 19th, 2009
This sounds silly but still i ask to be safe in my project.I want to use Cisco 1250 LAP with wireless controller.I want to use POE facility.There are around 7 1250 seried LAP AP.My question is :
01.Suppose the farthest access point (cisco 1250 with wireless n & around 5-6 DBI Omni Antenna) which needs power on poe is 110 meters away from poe switch.I want to use normal cat 6 utp cable to connect the A.P.
(a)How many meters maximum cat 6 utp needed to support poe? How should I check how much is dc voltage loss at the end of the A.P due to long cat 6 cable?
Thanx in advance.
Correct Answer by scottmac about 8 years 2 months ago
100 Meters (90 "in the wall," Solid conductor, + up to 5 meters of jumper cordage ,stranded conductor at each end, is the spec for TIA/EIA 568 structured cabling (and hence, POE).
If this is a commercial project, you may need to adjust your design accordingly, or you would be out of specification, for whatever liability that might present in your situation.
Good Luck
Scott
Overall Rating: 5 (1 ratings)
Correct Answer
scottmac Mon, 01/19/2009 - 11:57
  • Green, 3000 points or more
Good Luck
Scott
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
