Easy VPN-Virtual Office & DMVPN on same router
Jan 19th, 2009
Dear
We have 3845 router where my 5 sites are connecting with DMVPN using OSPF as routing protocol.
I would Like to achive following
For my Employe who will going work from home
i Would like to configure EASY VPN Virtual office concept
I am having cisco 877 with 4 port and adsl card....
My employe will connect head office usng EASY VPN nad also we will connect one of the ip phone..
I dont want to distrub any setting of existing DMVPN ....
bUT I WANT TO TERMINATE MY EASY VPN TUNNEL ON SAME 3845 ROUTER
TO ACHIVE THIS WHT I NEED TO CONFIGUR ON 3845 ROUTER
PLS HELP ME OUT
jitendra.pipalia Mon, 01/19/2009 - 23:30
Can u tell me one things I am using ospf routing protocol for DMVPN
is it i hve to make my 3845 as Esay vpn Server.and
my home user router esay vpn client...??
shld i have to use same ospf process ID for dmvpn and easy vpn ???
Ivan Martinon Tue, 01/20/2009 - 07:50
If your intention is to have that 3845 to accept ezvpn client connections then it has to be configured as ezvpn server as the link shows, OSPF will not pass along that ezvpn connection since it is a mulitcast setup.
jitendra.pipalia Tue, 01/20/2009 - 11:24
Hi Find attached configuration
My easy vpn tunnel not established even my user not able to brows internet though my ADSL line connect with ISP getting proper public ip on dialor0
Attached config file for easy vpn router
tell me pls wht i dod wrong
Ivan Martinon Tue, 01/20/2009 - 11:43
If your router cannot go to internet then certainly it will not be able to connect to your EZVPN server.
Check whether it is able to ping 4.2.2.2 from the router and if you are then I will need to you tell me why the group for the ezvpn is named "2" and why the ip address of the server (peer) is 1.1.1.1?
jitendra.pipalia Tue, 01/20/2009 - 12:58
my router getting public ip address from my ISP but my pc which is connected to vlan 1 is not able to go to internet ..
