Enable Auto-Registration During Business Hours?
jvweigand
We're getting ready to enable Auto-Registration on our CCM5.1.3 system. Is there any reason to not setup/enable it during business hours? I realize it'll cause a bit of a CPU/Network bandwidth hit when the phones start to register, but anything else beyond that?
Thanks in advance!
ok, then that discards overlapping. so the only chance that someone could dial it without knowing the number would be by mistake. if you don't think anyone could end up dialing one of the new numbers by mistake then you can use the existing partition/CSS
java
if this helps, please rate
java
Jaime Valencia
only make sure that at that time the phones are auto-registered in a partition still not available to regular users and no overlapping to avoid calling issues
java
java
The DN range we're going to use for it isn't used anywhere else, should we still have it blocked off? Or with no potential for overlap, could we use an existing partition/CSS?
java
java
