nat configuration
Jan 19th, 2009
basically we are to perform a what its called double nat on our asa5510.
on the outside int we have network and on the inside int we have
so basically i figured out that we had to perform a double-nat for this scenario.
can anyone help me out here on how do to it configuration wise.
Thanks in advance.
celiocarreto Tue, 01/20/2009 - 02:59
why double NAT?
My understanding of your scenario is, that you have a Router in Front of your firewall.
So, I would configure PAT on the firewall and static nat on the router.
global (outside) 1 interface
nat (inside) 1
ip nat inside source static x.x.x.x y.y.y.y
x.x.x.x = ASA IP
y.y.y.y = ISP IP
Regards, Celio
zulqurnain Wed, 01/21/2009 - 21:03
Thanks for the input, but I had already completed the objective.
Yes I also did the same what you are talking about. Thanks anyways.
