identify catalyst 6500 chasis
Answered Question
Jan 19th, 2009
I have a Catalyst 6509 but I do not know if it is a Cisco Catalyst 6509-E or Catalyst 6509-NEB or Catalyst 6509-NEB-A or Catalyst 6509-V-E
In the chassis is writen catalyst 6500 Series.
How do I know the chassis model??
I did show ver and it shows
cisco WS-C6509 (R5000) processor (revision 2.0) with 114688K/16384K bytes of memory.
Processor board ID SCA044304FF
How can i know wich model of chassis I have
Correct Answer by Mark Yeates about 5 years 3 months ago
From the output specified it appears that you have a standard 6509 chassis.
Mark
Average Rating: 5 (1 ratings)
languedoc Mon, 01/19/2009 - 14:46
but the command show idprom chassis does not apply
I found
show idprom:
all selects all FRU-types
backplane specify backplane
clock specify clock
earl specify earl
fan-tray specify fan-tray
interface interface name
module specify module
power-supply specify power-supply
rp specify RP (MSFC)
supervisor specify supervisor
vdb specify vdb
vtt specify VTT
#show idprom backplane
IDPROM for backplane #0
(FRU is 'Catalyst 6500 9-slot backplane')
OEM String = 'Cisco Systems'
Product Number = 'WS-C6509'
Serial Number = 'SCA044304FF'
Manufacturing Assembly Number = '73-3438-03'
Manufacturing Assembly Revision = 'B0'
Hardware Revision = 2.0
Current supplied (+) or consumed (-) = -
So i think is a Catalyst 6509 Switch
Am I rigth?
thanks
Mark Yeates Mon, 01/19/2009 - 14:47
On top of Glen's suggestion a "show inventory" will also display the type of chassis.
HTH,
Mark
glen.grant Mon, 01/19/2009 - 15:16
My bad show idprom chassis is for 4500's , cisco wouldn't want to keep it the same for all models that would make too much sense. Use the show idprom backplane , that is the chassis type you are dealing with .
Product Number = 'WS-C6509-E'
Serial Number = 'XXXXXXXXXXXXX'
Manufacturing Assembly Number = '73-9221-03'
Manufacturing Assembly Revision = 'A0'
Hardware Revision = 1.1
languedoc Mon, 01/19/2009 - 15:47
Salut
"show inventory" does not work on my switch
so i did
"show idprom backplane" and this gave:
Correct Answer
Mark Yeates Mon, 01/19/2009 - 18:34
Mark
Login or Register to take actions
Posted January 19, 2009 at 2:20 PM
Stats:
Replies:6 Avg. Rating:5
Views:1040 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
1 15,007
2 8,155
3 7,745
4 7,088
5 6,747
140
80
78
69
40
