Admin Context Access
i have two firewalls configured as an Active-Active, i created two contexts plus the admin context in each firewall.
as in the failover, one unit is acting as a Primary unit, and the other unit is acting as Secondary. so the primary unit is responsible for Running-Conf replication to the secondary one.
My Problem is:
the primary unit synchronize all the running configuration to the secondary, including the Admin Context configuration ( IP address.......).
i use the admin context for the management access to each firewall, so by this the two firewalls have the same IP address. which result of access problem to the secondary firewall.
i have to use the admin context for the management; because the management interface is used for the failover.
