Cant Connect to 3620 Router.
Jan 19th, 2009
Some one please help!
i was following this guide on how to transfer IOS images to a router.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml#proc_3600
Around the part where i changed the baud rate to 115200 The Tera Term which i use to connect to the router stopped working,
even the guides instructions to enter the new baud rate configuration doesnt work.
Can any one please tell me how i can make Tera Term see the router again?
glen.grant Tue, 01/20/2009 - 04:20
  • Purple, 4500 points or more
You changed the router to 115200 , did you then change tera term to 115200 , 8,n,1 so that they matched? You won't see anything if tera term was left at 9600 .
Ireneakue Tue, 01/20/2009 - 04:54
Woot! omg im finally in ~_~.
Yes, i changed Tera Term to 115200/8-n-1-hardware but it didnt work until i turned the router OFF/ON then Tera Term saw it! *phew*
