Route-Map
Jan 20th, 2009
I have created a Route-map as shown below:
access-list 119 permit ip host 10.130.100.27 host 10.5.118.150
access-list 119 permit ip host 10.130.100.27 host 10.5.118.151
access-list 119 permit ip host 10.130.100.28 host 10.5.118.150
access-list 119 permit ip host 10.130.100.28 host 10.5.118.151
route-map VPN permit 10
match ip address 119
set ip next-hop 10.130.2.7
interface Vlan100
description ***Data Server VLAN***
ip address 10.130.100.2 255.255.255.0
no ip redirects
ip policy route-map VPN
standby 1 ip 10.130.100.1
standby 1 priority 120
standby 1 preempt
Here the route-map is created to point all the traffic between the specified Source & Destination hits - 10.130.2.7. This is a VPN interface.
The route's at VPN end are intact. At the destination, I have a similar route cretaed & pointing to the VPN at the Far-end.
This was working completely fine & all of a sudden, now we witness that the route-map is not working & that the traffic between the host mentioned are not traversing the VPN.
What could be the problem? We have not made any changes in the configuration / environment.
Howver, we have some of other systems configured under access-list 119 which are traversing the VPN wothout any issues (i.e, route-map is working).
Please assist!
Giuseppe Larosa Tue, 01/20/2009 - 01:40
Hello Deepa,
Verify if the misbeahiving host's default gateway has been changed:
if so it is sending packets to another router where the PBR is not applied
have someone do
ipconfig /all
route print
on the misbeahving host the router cannot do PBR if packets are not sent to it.
Hope to help
Giuseppe
Kerem Gursu Tue, 01/20/2009 - 03:52
have you also checked the hsrp state between the active / standby routers?
Richard Burts Tue, 01/20/2009 - 04:21
Deepa
It might be helpful if we saw the entire access list 119. If some other devices are working with the route map then obviously there are other entries in the access list. Perhaps there is some order sensitivity in the access list?
It might also be helpful to do a tracert (or traceroute depending on what type of device it is) and see what is the next hop. Is it really the router with the route map configured?
It might also help if we knew what happens with traffic from those sources to those destinations. Does it get forwarded using regular routing logic or does that traffic get dropped? Especially if the traffic is dropped I would look carefully at the possibility that the route map is working and that there is some change or some problem with the VPN.
Rick
deepa.muralidharan Tue, 01/20/2009 - 19:33
Any traffic from 10.5.118.150 to 10.130.100.27 is getting routed as expected, ie, route-map is working & the traffic is getting routed via VPN. But the vice versa is not working. Any traffic from 10.130.100.27 is getting routed over our MPLS link rather than the VPN - route-map is not working
