speed betweent WIC-1T and WIC2T
edongskiu
i got an inquiry as i am upgrading the speed of the leased from 2Mbps to 10Mbps. My question is, does my existing WIC 1T (site 1) and WIC 2T accomodate the single 10Mbps line? I am not familiar with the speed support per card.
thanks in advance
regards,
Eduard
2 Accepted Solutions
Giuseppe Larosa
Hello Eduard,
as far as I know 10 Mbps are not possible on a single synchronous serial line unless HSSI (that is a different hardware)
Verify with your provider if they are going to give you a LAN (ethernet of FE ) termination
Hope to help
Giuseppe
Joseph W. Doherty
My guess would be your existing 2 Mbps is an E1 connect to your WIC-1T. Don't believe the 1T or 2T WICs will support more than 2 Mbps. To obtain 10 Mbps, you'll likely need either subrate E3 line and new interface to support it or an Ethernet handoff. Another option would be to use 5 E1s.
Giuseppe Larosa
Hello Eduard,
Hope to help
Giuseppe
Joseph W. Doherty
