Network health checksheet
Jan 20th, 2009
Hi all
I want to start doing a monthly network health check, ie sniffing, status of switches etc.
Has anyone got a check sheet for these types of things ?
jonathanaxford Tue, 01/20/2009 - 03:48
Hi Carl,
The best thing to do is get hold of some sort of SNMP monitoring system - this will do it all for you!
You can use SNMP to get all sorts of information from the switches/routers in your network, including number of collisions/errors on interfaces, this is usually a good way of identifying problems areas of the network.
