NAT overload problem
Jan 20th, 2009
I want to Translate all my internal addresses on my WAN cisco's address.
I have followed NAT overload configuration sample in Cisco documentation, but that doesn't work.
No translations are perfomed for my internal adresses.
Could you help me ?
jonathanaxford Tue, 01/20/2009 - 05:28
Hello there,
It looks like you need to add the IP nat outside and IP nat inside commands to the relevant interfaces...
interface vlan 1
ip nat inside
interface fa0/4
ip nat outside
Give that a try and see what happens...
garnier.1972 Tue, 01/20/2009 - 05:41
I've added this two statements on my conf (shame on me) but that's doesn't work too.
I've performed a "clear IP nat translation *" an restart a ping from my internal network to a WAN address but that's doesn't work.
I've attached new conf.
Tshi M Tue, 01/20/2009 - 06:46
Your config should work but try this as well:
ip nat pool test netmask
no ip nat inside source list 100 interface FastEthernet4 overload
ip nat inside source list 100 pool test overload
garnier.1972 Tue, 01/20/2009 - 07:37
That doesn't work too
But with "no ip cef" in configuration that's work (eiter with interface overload or pool overload) !!!
Why ?
lejoe.thomas Tue, 01/20/2009 - 05:35
Hi Garnier,
Please add the following
You need specify nat inside and nat outside interfaces.
int fastethernet4
ip nat outside
int vlan1
ip nat inside
armingojak Tue, 01/20/2009 - 05:36
try put "ip nat outside" on WAN interface, and "ip nat inside" on LAN interface...
