Antenna mounting question - AIR-ANT2506
Jan 20th, 2009
I was told by a wifi tech that the "pipe bomb" antenna [air-ant2506] should be installed upside down when installing inside a building, ie warehouse.
When I go to the hardware installation page for the antenna, Cisco makes no statement regarding this....they clearly show the antenna with the metal end at the bottom, not top.
http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/ant2506.html
Ultimately does it really matter which end is up if you are mounting inside? Just as long as it's vertical correct?
Scott Fella Tue, 01/20/2009 - 05:13
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You are right.... as long as they are verticle you should not have any issues. The reason why they might ask you to face it downward is due to code in some area's..... code sometimes states that there will not be any objects facing upward.... just in case someone falls. So it is more of a safety aspect.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
