IP Communicator used to reach dial up modem
Jan 20th, 2009
Is it possible to use Cisco IP Communicator to reach a dial-up modem instead of using the pots line?
I would appreciate any general guidance for this direction
Paolo Bevilacqua Tue, 01/20/2009 - 08:05
No, sorry. There are specialized applications (virtual com port) that can make a dial-up modem on a cisco router to appear like a local resource on the PC.
Hope this helps, please ratepost if it does!
npalmquist Tue, 01/20/2009 - 08:15
I can use putty to dial into a dial up modem and then I have terminal access. I think I need to clarify something.
Instead of using my modem and a pots line to reach the dial up modem, can an existing and functioning Cisco IP Communicator application be used to reach a dial up modem instead of a pots line? The device behind the modem may or may not be a Cisco Router. That is why your response confuses me
I can call the modem with Cisco IP Communicator. I hear the handshake. I guess I need to add Communicator as a modem on my laptop somehow?
I see a page on this website named "Modem Passthrough over Voice over IP" so I know it is supported, somehow, with some kind of configuration. Maybe the IP Communicator server can support this? Or maybe a new server needs to be built?
This idea is fresh, and I thought it may be as simple as installing a new modem on my laptop that uses IP Communicator to make the call. I need help to get started.
Paolo Bevilacqua Tue, 01/20/2009 - 08:44
Hi, you dial to remote modem, but there is no way the the ICPC will establish a modem connection, or emulate a modem for the PC.
And, neither a physical modem installed in the PC can use the ICPC or viceversa.
From that the recommendation that you install your own modems and then share them via virtual com port.
