configuration of AAA on a firewall module
Jan 20th, 2009
How to configure AAA on a FWSM (firewall module) on a catalyst C6509.
I need to protect the SSH accès on the firewall.
This is the command line that I use right now but it is not ok think:
aaa-server TEST protocol tacacs+
exit
aaa-server TEST host 192.168.200.167
key xxx
exit
no aaa authentication telnet console LOCAL
aaa authentication SSH console TEST LOCAL
Yudong Wu Wed, 01/21/2009 - 14:30
  • Gold, 750 points or more
1. Is AAA server in Inside network or Outside network? you mighit need to specify "interface name" in command 'aaa-server host".
2. Make sure your SSH config is correct.
You can just use LOCAL authentication to test if SSH is working fine.
3. In later code, you can use "test aaa-server" command to test the connectivity between FWSM and AAA server.
4. Make sure FWSM is added as AAA client in AAA server. Shared key is configured the same between FWSM and AAA server.
