BGP connection to 32bit ASN
Jan 20th, 2009
in order to configure peering between 16bit ASN and 32bit ASN - what is the requrement?
Would this be the correct configuration?
router bgp 45678
neighbor 1xx.0.0.2 remote-as 3.3
What software supports this configuration? (for C7600, RSP720)
According to Jeff Doyle we would need 12.2SRD, correct?
http://www.networkworld.com/community/node/35767
Jon
Overall Rating: 5 (2 ratings)
Harold Ritter Tue, 01/20/2009 - 09:07
Jon,
The 2 byte ASN IOS can't be configured for 4 byte ASN. It sees its 4 byte ASN neighbor as 23456 (reserved ASN for migration purposes).
router bgp 45678
neighbor 1xx.0.0.2 remote-as 23456
For availability of the 4 byte ASN on the 7600, please contact you account team.
jon.harald.bovr... Wed, 01/21/2009 - 04:24
Found IOS for 7200 to test customer CE as 32bit ASN (12.0.32S12).
Connected to old 16bit ASN.
Successful testing!
RIPE now assignes 32bit ASN. I would assume there to pop up some more prefix with as-path 23456 in few days.
Our customer will use Juniper as CE and are soon to be connected using 32bitASN.
